Picpol2 avatar image
Picpol2 asked
Send Alexa Events - Invalid Grant
I've followed the steps under "Authenticate a Customer to Alexa with Permissions," but I always get the following error message: {"error_description": "The request has an invalid grant parameter: code", "error": "invalid_grant"}. No matter if I make the authorization with my Lambda function or with the Python example code from Amazon provided under Alexa Smart Home: sample_async. I have checked the parameters grant_type, code, client_id, client_secret several times and can not find any errors.
The values for client_id, client_secret have been taken from the Developer Console under "Build-> PERMISSIONS-> Alexa Skill Messaging"
As value for code, I used "XXXXXXXXXXXX" from "directive.payload.grant.code" of AcceptGrant, which I received after successful account linking.:
    "directive": {
        "header": {
            "namespace": "Alexa.Authorization",
            "name": "AcceptGrant",
            "payloadVersion": "3",
            "messageId": "db52a26f-3fb3-4cf3-a948-d04d7c664fab"
        "payload": {
            "grant": {
                "type": "OAuth2.AuthorizationCode",
                "code": "XXXXXXXXXXXX"
            "grantee": {
                "type": "BearerToken",
                "token": "Atza|YYYYYY"
Does anyone have a tip for me?
Regards Werner
alexa smart homeaccount linkingpermissions
5 comments
After multiple deactivate => activate => account linking operations, the Python example works fine. Why my lambda code did not work at the beginning I do not know exactly. The only deliberate change I made was to specify "host" instead of "hostname" in the https options.
That's the root cause, "host" is the correct parameter for this http request.
Hi Picpol2, can you explain how you fixed this in more detail? I am getting the same error you had. What https options are you referring to? I'm using a call like:
lwa_data = {
                'grant_type': "authorization_code",
                'code': "<code from payload.grant.code>",
                'client_id': '<...>',
                'client_secret': '<...>'
            lwa_req = requests.post('https://api.amazon.com/auth/o2/token', data=lwa_data)
(I also tried adding allow_redirects and explicit headers as per sample_async.py:
LWA_HEADERS = {
                "Content-Type": "application/x-www-form-urlencoded;charset=UTF-8"
lwa_req = requests.post('https://api.amazon.com/auth/o2/token', headers=LWA_HEADERS, data=lwa_data, allow_redirects=True)
but it made no difference.)
I've logged and checked the outgoing request parameters and they look fine.
Would much appreciate any hints you can give me!
Hi SebW,
the post data needs to by url encoded (as you also specify in the content type).
You could use "querystring.stringify" to do this:
  const lwa_data = querystring.stringify({
    "grant_type" : "authorization_code",
    "code" : code,
    "client_id" : "xxx",
    "client_secret" : "xxx"
Best regards
Werner
