newuser-328d341a-d2fa-42f3-80b5-694b06377b9c avatar image
newuser-328d341a-d2fa-42f3-80b5-694b06377b9c asked ·
Sales reporting API returning results only up to Sept. 20
Hello, I've created a script which downloads app reports through you API (more specifically - "Sales Reporting API"). I had the script downloading the report every morning , parse the csv and import it into my database for a comparable graph. This was working fine for probably a month now, untill today when I noticed that the data is only showing up untill sept. 20'th, while 21'st has much more installs / in-aps purchases and overall interactions than before according to your dashboard view. I've deleted this months report file and launched the script manually to check if it downloads the data, and it does, but the data is still showing only up to setp. 20th. Could you guys check that the reporting API is working fine on your end?
reporting
Levon@Amazon avatar image
Levon@Amazon answered ·
Hi there,
Thank you for bringing this issue to our attention. We have now identified and fixed the problem, and you should be able to see your updated sales transactions now. Thanks!
newuser-328d341a-d2fa-42f3-80b5-694b06377b9c answered ·
thank you!
