newuser-748b3724-1f9c-48d6-96a2-8f9fadcc0591 avatar image
Why does the Fallback Intent not get called if you say ONE random word?
Whenever I go inside the skill and say one completely random word, the Fallback Intent is not triggered. The echo will just emit a sound and in the Alexa simulator, it would just show nothing. But I know for a fact that I am still inside the skill and the session has not yet ended since if I try to say an utterance that is mapped to a certain intent without including the word Alexa, it would respond correctly. BUT, if I try to say TWO completely random words the Fallback Intent is triggered. For example(this is already inside the skill), if I say the word "pizza" it would just respond with that weird noise and stay in the current session. But if I say the words "pizza pie" it would map to the Fallback Intent.
I have observed this behavior in a skill that has many custom intents each having many utterances configured. But when I tried inputting the word "pizza" to a skill with only 3 custom intents, the Fallback intent works fine.
intentsutterancessessionfallbackintent
Anand@Amazon avatar image
Anand@Amazon answered
Hello Developer,
Please share skill id for further debugging.
Rokas avatar image
Rokas answered
I spotted the same issue with fallback intent. It is really hard to invoke it if you have a slot with a lot of value, because it gets matched to something, even though as you said it might be a random word. If you leave just a couple of values in the slot, fallback intent gets invoked easier.
I have no idea how to fix it in the model, but I handle everything in the backend code. If value doesn't match value I want, I redirect that call to fallback intent code.
2 comments
D. Walker avatar image D. Walker commented ·
Set validation in the Intent to be strictly from your list. Other single random words should hit the fallback then.
MediaRez avatar image MediaRez D. Walker commented ·
I'm having a similar issue and tried exactly this - forcing my only one-word intent to only match the 5 words it's supposed to match. This still caused the model to fail to match other one-word utterances to either that intent or the FallbackIntent (though utterance profiler says both were considered). Quite frustrating, I hope someone can figure this out!
Vlad avatar image
Vlad answered
Did you guys ever figure it out?
I noticed the same behavior, logged case 5559384951 for the same. No feedback so far
Anand@Amazon avatar image Anand@Amazon ♦ commented ·
Hey Vlad,
I think Jason already reached put to you on your query and please follow contact us case for further response.
newuser-467ea0c6-1a43-4b1a-8ceb-e13410537579 avatar image
newuser-467ea0c6-1a43-4b1a-8ceb-e13410537579 answered
HI , I am too facing the same issue. Please let us know if there is any solution?
Hi there,
Can you share skill id wit us for further investigation?
Jamhead avatar image
Jamhead answered
I'm having the same issue, opened question https://forums.developer.amazon.com/questions/212237/fallback-intent-not-firing.html for it and no response yet.
Rodrigo avatar image
Rodrigo answered
I think I just found the solution...
Having single word on any intent, Alexa by mistake (obviously), tends to match a single word interaction with some intent with a single word as sample utterances!!!!!!
As I see, Alexa uses the terms and the term count to calculate the statistical match with user interaction... wow!
Hope it helps you guys!!!
