I am under proxy. So i am not able to use the ask-cli module. Since, it fails to fire the amazon api. i guess!! So, i can't use any other commands like ask deploy etc.
I use linux environment.
Have tried all possibilities like setting env variables as per this link,
I have the updated modules,
$ node -v
v10.9.0
$ npm -v
6.2.0
$ ask -v
1.4.2
Below is the terminal log - linux.
[brgvkmr@localhost ~]$ ask init --no-browser
? Please create a new profile or overwrite the existing profile.
[brgvkmr] "default"
-------------------- Initialize CLI --------------------
Setting up ask profile: [brgvkmr]
? Please choose one from the following AWS profiles for skill's Lambda function deployment.
Use the AWS environment variables.
Paste the following url to your browser:
https://www.amazon.com/ap/oa/xyz #some url which opens for authentication and returns back the Auth code.
? Please enter the Authorization Code: #auth_code
Tokens fetched and recorded in ask-cli config.
Request to the Alexa Skill Management API service failed. // error
Tried using --debug flag,
-------------------- Debug Mode --------------------
/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/lib/utils/logger-utility.js:37
console.warn('[' + item.time + '] - ' + LEVEL_MAPPING[item.level] + ' - ' + item.activity.toUpperCase());
TypeError: Cannot read property 'toUpperCase' of undefined
at displayLogs (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/lib/utils/logger-utility.js:37:106)
at process.on (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/lib/utils/logger-utility.js:61:13)
at emitOne (events.js:101:20)
at process.emit (events.js:188:7)
at processEmit [as emit] (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/node_modules/signal-exit/index.js:149:35)
at process.exit (internal/process.js:146:15)
at Request.request [as _callback] (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/lib/api/request-wrapper.js:52:25)
at self.callback (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/node_modules/request/request.js:185:22)
at emitOne (events.js:96:13)
at Request.emit (events.js:188:7)
at Request.onRequestError (/home/appuser/bhargavWorkSpace/node-v6.10.0/lib/node_modules/ask-cli/node_modules/request/request.js:881:8)
at ClientRequest.emit (events.js:188:7)
at TLSSocket.socketErrorListener (_http_client.js:310:9)
at TLSSocket.emit (events.js:188:7)
