Getting this runtime exception while invoking ADM instance on Fire tablet 10. I have done all the required steps required for ADM.
E/Precog_API: Can't connect to Service: Intent { cmp=com.amazon.precog/.service.PrecogService } Got Exception calling recordEvent android.os.RemoteException: Couldn't connect to Service at com.amazon.precog.api.PrecogService.connectLocked(PrecogService.java:159) at com.amazon.precog.api.PrecogService.access$200(PrecogService.java:38) at com.amazon.precog.api.PrecogService$6.run(PrecogService.java:332) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:422) at java.util.concurrent.FutureTask.run(FutureTask.java:237) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:152) at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:265) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1112) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:587) at java.lang.Thread.run(Thread.java:818)
E/AndroidRuntime: FATAL EXCEPTION: main Process: com.immediasemi.android.blink, PID: 24242 java.lang.RuntimeException: Unable to create application com.immediasemi.blink.BlinkApp: java.lang.RuntimeException: Stub! at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4777) at android.app.ActivityThread.access$1500(ActivityThread.java:160) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1382) at android.os.Handler.dispatchMessage(Handler.java:102) at android.os.Looper.loop(Looper.java:135) at android.app.ActivityThread.main(ActivityThread.java:5491) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:984) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:779) Caused by: java.lang.RuntimeException: Stub! at com.amazon.device.messaging.ADM.<init>(Unknown Source) at com.immediasemi.blink.BlinkApp.onCreate(BlinkApp.java:279) at android.app.Instrumentation.callApplicationOnCreate(Instrumentation.java:1015) at android.app.ActivityThread.handleBindApplication(ActivityThread.java:4774) at android.app.ActivityThread.access$1500(ActivityThread.java:160) at android.app.ActivityThread$H.handleMessage(ActivityThread.java:1382) at android.os.Handler.dispatchMessage(Handler.java:102) at android.os.Looper.loop(Looper.java:135) at android.app.ActivityThread.main(ActivityThread.java:5491) at java.lang.reflect.Method.invoke(Native Method) at java.lang.reflect.Method.invoke(Method.java:372) at com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run(ZygoteInit.java:984) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:779)
