sabrine avatar image
sabrine asked
Is DRM playback supported thru the use of ExoPlayer integrated with Cordova?
We are currently building a hybrid FireTV application, using HTML5, JS (VueJS) and CSS3 wrapped into a native app using Cordova. Our requirement is to support DRM content.
Questions:
  1. Is DRM playback supported thru the use of ExoPlayer integrated with Cordova?
  2. Should we develop the ExoPlayer plugin ourselves or is there an existing one you suggest us to use?
fire tvweb apps
Levon@Amazon avatar image
Levon@Amazon answered
Hi sabrine,
If you are using a separate ExoPlayer, for example through a Cordova plugin or something else, then DRM support would be listed on the ExoPlayer documentation here: https://google.github.io/ExoPlayer/drm.html
Thanks!
