all worked fine few days ago, no changes were made - just stopped recognizing the skill.
skill id: amzn1.ask.skill.cae6d25b-7604-44ec-aaf2-9d8283d50ee6
Hello Kan,
Your skill's invocation name invoking another skill called "Geek Humor" and asking user to enable in their account. Can you change your skill invocation name and try again?
Hello Kan,
Apologies for late reply.
I have tested your skill in test simulator and it looks like it is working now.
it can't find my skill so the nearest one that sounds like it is "geek humor". the problem is that my skill invocation cannot be found. even in test simulator when i'm typing not speaking it won't recognize it.
i have tried with different invocation names. same result.
i can see other posts here about skills configured for Ausrtalian English not working, i wonder if this is the case here as well?
i can confirm now that the issue only happens for AU English. i have duplicated the setup to GB-EN and it's working.
can someone look into what's wrong with Australian config processing?
Hello Kan,
We are aware of this issue and we have already reached out to concerned team and they are working on this issue. I will update you once I will get any response from them.
2 People are following this question.
