newuser-5e1e3e1b-007d-42da-b023-2bbf12a51b2a avatar image
newuser-5e1e3e1b-007d-42da-b023-2bbf12a51b2a asked ·
Adding adafruitIO libraries to AWS Lambda
i am very new in the Alexa skill development area, i and i apologies if this question has been asked before, but i cant seem to find the right answer to my problem. Basically i want alexa to read a value from Adafruit IO. I have the python script working on my PC and i want to port it over to AWS lambda, but i when i run my script, alexa doesnt seem to respond. I followed the following steps from the website
https://docs.aws.amazon.com/lambda/latest/dg/lambda-python-how-to-create-deployment-package.html
after doing that, it looks something like this.
The base code is taken from this website. I can get this skill to work.
https://medium.com/crowdbotics/how-to-build-a-custom-amazon-alexa-skill-step-by-step-my-favorite-chess-player-dcc0edae53fb
and the Adafruit IO script is as bellow. This script also works on my PC when i did my "pip-install"
# Import library and create instance of REST client.
from Adafruit_IO import Client
aio = Client('XXXX', 'XXXX')
# Get an array of all data from feed 'Test'
data = aio.data('test')
# Print out all the results.
for d in data:
    print('{0}'.format(d.value))
Essentially, my main aim is to query alexa for the status of the Adafruit IO. Once i added the first line
the code stops working. Every time i trigger the skill, i get
"There was a problem with the requested skill's response"
i'm not sure what is going on I really appreciate you guys helping out.
Thanks in advance
alexa skills kitlambdapython
Jenn@amazon avatar image
Jenn@amazon answered ·
Sounds like an issue with the Lambda Function. Look at the CloudWatch logs, any errors will get printed to the logs for easier troubleshooting.
newuser-5e1e3e1b-007d-42da-b023-2bbf12a51b2a answered ·
Thanks for the reply, i actually figured it out =) i realised i needed to import urllib to get it to work. it works just fine now!
