anoop4real avatar image
anoop4real asked
AWS Lambda: Properly uploading a zip
I am writing a skill which requires aws-sdk, so I have created a zip with the below contents in root
index.js
node_modules
package.json
After uploading to AWS, inline editing was not available (that's understood). Now when I try to test my Alexa skill, I get the below error
Unable to import module 'index': Error
    at Function.Module._resolveFilename (module.js:469:15)
    at Function.Module._load (module.js:417:25)
    at Module.require (module.js:497:17)
    at require (internal/module.js:20:19)
Looks like index.js is not getting found. I have put all the files in root and zipped
I then tried to upload a small project and below is my observation. By default when you create a function from scratch there is a folder created and when we upload the zip, on unzip there is a folder created again as part of unzip which is probably causing the issue, please see the screenshots below.
On Creation
After Zip upload
If inline editing is available, you can fix this by rearranging files, but if inline editing is not available, we cant fix it. Need urgent help on this
alexa skills kitlambdaaws
Arun Pattni avatar image
Arun Pattni answered
I've run into this issue before. The problem is the way that you are zipping it. You need to zip the files, not the folder. See the image below for what I mean
4 comments
Thanks for the reply, I have tried with the files also, it will create a default archive folder when I compress it from MAC. Do I need to use 7zip?
-anoop
@Arun Pattni
I tried again and it worked, thanks for the pointer
can u please share the image once again
Rokas avatar image Rokas newuser-64a41272-f9be-4eda-8d84-71a5b807515c ·
What problem are you having with zipping? Just zip the contents of lambda folder, not the lambda folder itself.
anoop4real answered
Any pointers?
