Piotreeek avatar image
Piotreeek asked
Smart home discovery failure
I have been using a custom smart home skill for some time. One day - it stopped working. It turns out it doesn't discover my devices. I recoded it, pasted sample code and it doesn't find any devices, however I do not receive any errors. Can you please have a look at my sample request and response to rule out an obvious error?
  "directive": {
    "header": {
      "namespace": "Alexa.Discovery",
      "name": "Discover",
      "payloadVersion": "3",
      "messageId": "1bd5d003-31b9-476f-ad03-71d471922820"
    "payload": {
      "scope": {
        "type": "BearerToken",
        "token": "access-token-from-skill"
  "event": {
    "header": {
      "name": "Discover.Response",
    "payload": {
      "endpoints": [
          "endpointId": "demo_id",
          "manufacturerName": "Smart Device Company",
          "friendlyName": "Bedroom Outlet",
          "description": "Smart Device Switch",
          "displayCategories": [
            "SWITCH"
          "cookie": {
            "key1": "arbitrary key/value pairs to reference this endpoint.",
            "key2": "There can be multiple entries",
            "key3": "but they should only be used for reference purposes.",
            "key4": "This is not a suitable place to oint state."
          "capabilities": [
              "type": "AlexaInterface",
              "interface": "Alexa",
              "version": "3"
              "interface": "Alexa.PowerController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "powerState"
                "retrievable": true
alexa skills kitalexa smart homesmart homedevice discovery
Tsuneki@Amazon avatar image
Tsuneki@Amazon answered
Hi there,
Thanks for posting.
Could you please disable "Send Alexa event" and try again?
If it work with disabling it, Authorization interface is missing or not properly implemented in your lambda function.
Please check here for detail.
Piotreeek answered
It doesn't work with either disabled or enabled
My skill is
amzn1.ask.skill.106debc9-e968-4115-acaf-4b1a0348fcb2
can you have a look a\t this. Also, I'm still getting a "Skill I/O is available only for speech requests to skills you have created." output. I have tried every possible solutions to that. No luck, though
Hi there,
Could you please file a contact us here with your account linking ID and password which already connected to your device so that we can reproduce the issue locally and assist further.
Regards,
Tsuneki
