I'm having an issue with new intents breaking a specific intent in my skill(the endrecordingIntent), even though their logic is completely independent. I tested out adding a new dummy intent (through the aws front end sdk) whose logic i haven't even included in lambda aws and saw the same error of "there was a problem in your requested skills response" instead of the expected outcome. I have no idea what could be going wrong at this point, any tips on what could be causing the issue are appreciated. See code below. Thanks!
"use strict"; var Alexa = require("alexa-sdk"); <br>var AWS = require('aws-sdk'); <br>const APP_ID = 'amzn1.ask.skill.6f4eefbb-f0aa-474f-82c6-9394bcb2335c'; <br>var ddb = new AWS.DynamoDB.DocumentClient(); <br>var userLocation; var handlers = { 'LaunchRequest': function(){ this.emit(":ask", "Welcome to seizure support, a voice enabled seizure tracker, say your location to complete setup."); <br> }, 'citiesIntent': function(){<br>// user responds with their city location after the onLaunch event. After this point, the // // stopRecordingIntent doesn't work - recordIntent and seizureTypeIntent both still function // <br>// userLocation = this.event.request.intent.slots.UScity.value; <br>// this.response.speak(userLocation + " has been set"); <br>// this.emit(':responseReady'); <br> }, 'recordIntent': async function() { var date = new Date(); <br> var startTime = `${date.getHours()}:${date.getMinutes()}:${date.getSeconds()}`; var dateStamp = `${date.getMonth()}-${date.getDate()}-${date.getFullYear()}`; this.attributes['startTime'] = startTime; this.attributes['date'] = dateStamp; var params = { TableName: '######', <br> Item:{ "startTime": this.attributes['startTime'], <br> "date": dateStamp, } }; await ddb.put(params,(err,data)=>{ if (err){ console.log(err) }else{ console.log(data) } }).promise(); <br>this.emit(":ask", "Recording"); <br> },'stopRecordingintent': async function(){<br>//failure is here //<br> var date = new Date(); var endTime = `${date.getHours()}:${date.getMinutes()}:${date.getSeconds()}`; <br> var params = { TableName:'#######', Key:{ startTime : this.attributes['startTime'], date : this.attributes['date'] },<br>UpdateExpression: "set endTime =:endTime", ExpressionAttributeValues:{ ":endTime":endTime }, ReturnValues:"UPDATED_NEW" }; <br> await ddb.update(params,(err,data)=>{ if (err){ this.response.speak(err); this.emit(':responseReady'); }else{ this.emit(":ask", "Ending recording, say seizure type or skip to end session."); } }).promise(); <br> },'seizureTypeintent': async function(){ <br> var date = new Date(); <br> var seizureCategory = this.event.request.intent.slots.seizure.value; <br> var params = { TableName:'#########', Key:{ startTime : this.attributes['startTime'], date : this.attributes['date'] }, UpdateExpression: "set seizureType =:seizureType", ExpressionAttributeValues:{ ":seizureType": seizureCategory }, ReturnValues:"UPDATED_NEW" }; <br> await ddb.update(params,(err,data)=>{ if (err){ console.log(err) }else{ this.response.speak("Information has been recorded.") this.emit(':responseReady'); } }).promise(); //end }<br>}<br>exports.handler = function(event, context, callback){ var alexa = Alexa.handler(event, context); alexa.appId = APP_ID; alexa.registerHandlers(handlers); alexa.execute(); };
