I am displaying/adding banner adv in my application. but banner adv are not displaying,I am implementing banner adv using Android Studio.Here are the files and logcat.
1-(activity_main.xml)
<?xml version="1.0" encoding="utf-8"?> <LinearLayout xmlns:android="http://schemas.android.com/apk/res/android" xmlns:Amazon="http://schemas.android.com/apk/lib/com.amazon.device.ads" xmlns:tools="http://schemas.android.com/tools" android:id="@+id/Main" android:layout_width="match_parent" android:layout_height="match_parent" android:orientation="vertical" tools:context="com.bozon.shubh.pen.bozonink.MainActivity"> <com.amazon.device.ads.AdLayout android:id="@+id/ad_view" android:layout_width="320dp" android:layout_height="50dp" Amazon:adSize="320x50" /> </LinearLayout>
2-MainActivity.java
package com.bozon.shubh.pen.bozonink; import android.support.v7.app.AppCompatActivity; import android.os.Bundle; import com.amazon.device.ads.*; public class MainActivity extends AppCompatActivity { private AdLayout adView; public InterstitialAd interstitialAd; @Override protected void onCreate(Bundle savedInstanceState) { super.onCreate(savedInstanceState); setContentView(R.layout.activity_main); AdRegistration.setAppKey("6c563ab13316436bb8551162e8c22e13"); this.adView = (AdLayout) findViewById(R.id.ad_view); AdTargetingOptions adOptions = new AdTargetingOptions(); // Optional: Set ad targeting options here. this.adView.loadAd(adOptions);// Retrieves an ad on background thread this.adView.showAd(); } }
3-logcat
07-07 02:45:28.149 7593-7593/? I/art: Late-enabling -Xcheck:jni 07-07 02:45:28.170 7593-7601/? I/art: Debugger is no longer active 07-07 02:45:28.170 7593-7601/? I/art: Starting a blocking GC Instrumentation 07-07 02:45:28.200 7593-7593/? D/LenovoAppIconTheme: ExtraResources;cleanCachedIcon;clear cache.. 07-07 02:45:28.561 7593-7593/? W/System: ClassLoader referenced unknown path: /data/app/com.bozon.shubh.pen.bozoninkpen-2/lib/arm 07-07 02:45:28.577 7593-7593/? I/MultiDex: VM with version 2.1.0 has multidex support 07-07 02:45:28.577 7593-7593/? I/MultiDex: Installing application 07-07 02:45:28.577 7593-7593/? I/MultiDex: VM has multidex support, MultiDex support library is disabled. 07-07 02:45:28.580 7593-7593/? I/InstantRun: starting instant run server: is main process 07-07 02:45:28.670 7593-7593/? W/art: Before Android 4.1, method android.graphics.PorterDuffColorFilter android.support.graphics.drawable.VectorDrawableCompat.updateTintFilter(android.graphics.PorterDuffColorFilter, android.content.res.ColorStateList, android.graphics.PorterDuff$Mode) would have incorrectly overridden the package-private method in android.graphics.drawable.Drawable 07-07 02:45:28.716 7593-7593/? V/BoostFramework: mAcquireFunc method = public int com.qualcomm.qti.Performance.perfLockAcquire(int,int[]) 07-07 02:45:28.716 7593-7593/? V/BoostFramework: mReleaseFunc method = public int com.qualcomm.qti.Performance.perfLockRelease() 07-07 02:45:28.716 7593-7593/? V/BoostFramework: mAcquireTouchFunc method = public int com.qualcomm.qti.Performance.perfLockAcquireTouch(android.view.MotionEvent,android.util.DisplayMetrics,int,int[]) 07-07 02:45:28.716 7593-7593/? V/BoostFramework: mIOPStart method = public int com.qualcomm.qti.Performance.perfIOPrefetchStart(int,java.lang.String) 07-07 02:45:28.716 7593-7593/? V/BoostFramework: mIOPStop method = public int com.qualcomm.qti.Performance.perfIOPrefetchStop() 07-07 02:45:28.718 7593-7593/? V/BoostFramework: BoostFramework() : mPerf = com.qualcomm.qti.Performance@911cec2 07-07 02:45:28.718 7593-7593/? V/BoostFramework: BoostFramework() : mPerf = com.qualcomm.qti.Performance@5a054d3 07-07 02:45:28.878 7593-7593/? I/WebViewFactory: Loading com.android.chrome version 67.0.3396.87 (code 339608702) 07-07 02:45:28.929 7593-7593/? I/cr_LibraryLoader: Time to load native libraries: 5 ms (timestamps 6377-6382) 07-07 02:45:28.935 7593-7593/? I/chromium: [INFO:library_loader_hooks.cc(36)] Chromium logging enabled: level = 0, default verbosity = 0 07-07 02:45:28.936 7593-7593/? I/cr_LibraryLoader: Expected native library version number "67.0.3396.87", actual native library version number "67.0.3396.87" 07-07 02:45:28.969 7593-7593/? I/cr_BrowserStartup: Initializing chromium process, singleProcess=true 07-07 02:45:28.970 7593-7593/? I/cr_base: Android Locale: en_IN requires .pak files: [en-GB.pak, en-US.pak] 07-07 02:45:28.991 7593-7593/? W/ResourceType: Failure getting entry for 0x7f120479 (t=17 e=1145) (error -2147483647) 07-07 02:45:29.063 7593-7593/? I/art: Rejecting re-init on previously-failed class java.lang.Class<vp>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/webkit/SafeBrowsingResponse; 07-07 02:45:29.063 7593-7593/? I/art: at void com.android.webview.chromium.WebViewChromium.init(java.util.Map, boolean) (PG:53) 07-07 02:45:29.063 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int, java.util.Map, boolean) (WebView.java:636) 07-07 02:45:29.063 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int) (WebView.java:572) 07-07 02:45:29.063 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int) (WebView.java:555) 07-07 02:45:29.063 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet) (WebView.java:542) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context) (WebView.java:532) 07-07 02:45:29.064 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory$WebViewConstructor.createWebView(android.content.Context) (WebViewFactory.java:187) 07-07 02:45:29.064 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory.createWebView(android.content.Context) (WebViewFactory.java:59) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager$1.run() (UserAgentManager.java:70) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadExecutor.execute(java.lang.Runnable) (ThreadUtils.java:364) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadRunner.execute(java.lang.Runnable, com.amazon.device.ads.ThreadUtils$ExecutionStyle, com.amazon.device.ads.ThreadUtils$ExecutionThread) (ThreadUtils.java:173) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager.populateUserAgentString(android.content.Context) (UserAgentManager.java:65) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.DeviceInfo.populateUserAgentString(android.content.Context) (DeviceInfo.java:364) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdController.prepareForAdLoad(long, boolean) (AdController.java:869) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdSlot.prepareForAdLoad(long) (AdSlot.java:118) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.AdLoadStarter.loadAds(int, com.amazon.device.ads.AdTargetingOptions, com.amazon.device.ads.AdSlot[]) (AdLoadStarter.java:94) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdLayout.loadAd(com.amazon.device.ads.AdTargetingOptions) (AdLayout.java:764) 07-07 02:45:29.064 7593-7593/? I/art: at void com.bozon.shubh.pen.bozonink.MainActivity.onCreate(android.os.Bundle) (MainActivity.java:22) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6705) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1119) 07-07 02:45:29.064 7593-7593/? I/art: at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2599) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2707) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.-wrap12(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1460) 07-07 02:45:29.064 7593-7593/? I/art: at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:102) 07-07 02:45:29.064 7593-7593/? I/art: at void android.os.Looper.loop() (Looper.java:154) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6077) 07-07 02:45:29.064 7593-7593/? I/art: at java.lang.Object java.lang.reflect.Method.invoke!(java.lang.Object, java.lang.Object[]) (Method.java:-2) 07-07 02:45:29.064 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run() (ZygoteInit.java:865) 07-07 02:45:29.064 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:755) 07-07 02:45:29.064 7593-7593/? I/art: Caused by: java.lang.ClassNotFoundException: Didn't find class "android.webkit.SafeBrowsingResponse" on path: DexPathList[[zip file "/data/app/com.android.chrome-1/base.apk"],nativeLibraryDirectories=[/data/app/com.android.chrome-1/lib/arm, /data/app/com.android.chrome-1/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]] 07-07 02:45:29.064 7593-7593/? I/art: at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:56) 07-07 02:45:29.064 7593-7593/? I/art: at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:380) 07-07 02:45:29.064 7593-7593/? I/art: at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312) 07-07 02:45:29.064 7593-7593/? I/art: at void com.android.webview.chromium.WebViewChromium.init(java.util.Map, boolean) (PG:53) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int, java.util.Map, boolean) (WebView.java:636) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int) (WebView.java:572) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int) (WebView.java:555) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet) (WebView.java:542) 07-07 02:45:29.064 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context) (WebView.java:532) 07-07 02:45:29.064 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory$WebViewConstructor.createWebView(android.content.Context) (WebViewFactory.java:187) 07-07 02:45:29.064 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory.createWebView(android.content.Context) (WebViewFactory.java:59) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager$1.run() (UserAgentManager.java:70) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadExecutor.execute(java.lang.Runnable) (ThreadUtils.java:364) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadRunner.execute(java.lang.Runnable, com.amazon.device.ads.ThreadUtils$ExecutionStyle, com.amazon.device.ads.ThreadUtils$ExecutionThread) (ThreadUtils.java:173) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager.populateUserAgentString(android.content.Context) (UserAgentManager.java:65) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.DeviceInfo.populateUserAgentString(android.content.Context) (DeviceInfo.java:364) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdController.prepareForAdLoad(long, boolean) (AdController.java:869) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdSlot.prepareForAdLoad(long) (AdSlot.java:118) 07-07 02:45:29.064 7593-7593/? I/art: at void com.amazon.device.ads.AdLoadStarter.loadAds(int, com.amazon.device.ads.AdTargetingOptions, com.amazon.device.ads.AdSlot[]) (AdLoadStarter.java:94) 07-07 02:45:29.064 7593-7593/? I/art: at boolean com.amazon.device.ads.AdLayout.loadAd(com.amazon.device.ads.AdTargetingOptions) (AdLayout.java:764) 07-07 02:45:29.064 7593-7593/? I/art: at void com.bozon.shubh.pen.bozonink.MainActivity.onCreate(android.os.Bundle) (MainActivity.java:22) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6705) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1119) 07-07 02:45:29.064 7593-7593/? I/art: at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2599) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2707) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.-wrap12(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1460) 07-07 02:45:29.064 7593-7593/? I/art: at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:102) 07-07 02:45:29.064 7593-7593/? I/art: at void android.os.Looper.loop() (Looper.java:154) 07-07 02:45:29.064 7593-7593/? I/art: at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6077) 07-07 02:45:29.064 7593-7593/? I/art: at java.lang.Object java.lang.reflect.Method.invoke!(java.lang.Object, java.lang.Object[]) (Method.java:-2) 07-07 02:45:29.064 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run() (ZygoteInit.java:865) 07-07 02:45:29.064 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:755) 07-07 02:45:29.072 7593-7593/? I/art: Rejecting re-init on previously-failed class java.lang.Class<yt>: java.lang.NoClassDefFoundError: Failed resolution of: Landroid/webkit/RenderProcessGoneDetail; 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.webview.chromium.WebViewChromium.init(java.util.Map, boolean) (PG:53) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int, java.util.Map, boolean) (WebView.java:636) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int) (WebView.java:572) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int) (WebView.java:555) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet) (WebView.java:542) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context) (WebView.java:532) 07-07 02:45:29.072 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory$WebViewConstructor.createWebView(android.content.Context) (WebViewFactory.java:187) 07-07 02:45:29.072 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory.createWebView(android.content.Context) (WebViewFactory.java:59) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager$1.run() (UserAgentManager.java:70) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadExecutor.execute(java.lang.Runnable) (ThreadUtils.java:364) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadRunner.execute(java.lang.Runnable, com.amazon.device.ads.ThreadUtils$ExecutionStyle, com.amazon.device.ads.ThreadUtils$ExecutionThread) (ThreadUtils.java:173) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager.populateUserAgentString(android.content.Context) (UserAgentManager.java:65) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.DeviceInfo.populateUserAgentString(android.content.Context) (DeviceInfo.java:364) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdController.prepareForAdLoad(long, boolean) (AdController.java:869) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdSlot.prepareForAdLoad(long) (AdSlot.java:118) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.AdLoadStarter.loadAds(int, com.amazon.device.ads.AdTargetingOptions, com.amazon.device.ads.AdSlot[]) (AdLoadStarter.java:94) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdLayout.loadAd(com.amazon.device.ads.AdTargetingOptions) (AdLayout.java:764) 07-07 02:45:29.072 7593-7593/? I/art: at void com.bozon.shubh.pen.bozonink.MainActivity.onCreate(android.os.Bundle) (MainActivity.java:22) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6705) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1119) 07-07 02:45:29.072 7593-7593/? I/art: at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2599) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2707) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.-wrap12(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1460) 07-07 02:45:29.072 7593-7593/? I/art: at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:102) 07-07 02:45:29.072 7593-7593/? I/art: at void android.os.Looper.loop() (Looper.java:154) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6077) 07-07 02:45:29.072 7593-7593/? I/art: at java.lang.Object java.lang.reflect.Method.invoke!(java.lang.Object, java.lang.Object[]) (Method.java:-2) 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run() (ZygoteInit.java:865) 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:755) 07-07 02:45:29.072 7593-7593/? I/art: Caused by: java.lang.ClassNotFoundException: Didn't find class "android.webkit.RenderProcessGoneDetail" on path: DexPathList[[zip file "/data/app/com.android.chrome-1/base.apk"],nativeLibraryDirectories=[/data/app/com.android.chrome-1/lib/arm, /data/app/com.android.chrome-1/base.apk!/lib/armeabi-v7a, /system/lib, /vendor/lib]] 07-07 02:45:29.072 7593-7593/? I/art: at java.lang.Class dalvik.system.BaseDexClassLoader.findClass(java.lang.String) (BaseDexClassLoader.java:56) 07-07 02:45:29.072 7593-7593/? I/art: at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String, boolean) (ClassLoader.java:380) 07-07 02:45:29.072 7593-7593/? I/art: at java.lang.Class java.lang.ClassLoader.loadClass(java.lang.String) (ClassLoader.java:312) 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.webview.chromium.WebViewChromium.init(java.util.Map, boolean) (PG:53) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int, java.util.Map, boolean) (WebView.java:636) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int, int) (WebView.java:572) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet, int) (WebView.java:555) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context, android.util.AttributeSet) (WebView.java:542) 07-07 02:45:29.072 7593-7593/? I/art: at void android.webkit.WebView.<init>(android.content.Context) (WebView.java:532) 07-07 02:45:29.072 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory$WebViewConstructor.createWebView(android.content.Context) (WebViewFactory.java:187) 07-07 02:45:29.072 7593-7593/? I/art: at android.webkit.WebView com.amazon.device.ads.WebViewFactory.createWebView(android.content.Context) (WebViewFactory.java:59) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager$1.run() (UserAgentManager.java:70) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadExecutor.execute(java.lang.Runnable) (ThreadUtils.java:364) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.ThreadUtils$ThreadRunner.execute(java.lang.Runnable, com.amazon.device.ads.ThreadUtils$ExecutionStyle, com.amazon.device.ads.ThreadUtils$ExecutionThread) (ThreadUtils.java:173) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.UserAgentManager.populateUserAgentString(android.content.Context) (UserAgentManager.java:65) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.DeviceInfo.populateUserAgentString(android.content.Context) (DeviceInfo.java:364) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdController.prepareForAdLoad(long, boolean) (AdController.java:869) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdSlot.prepareForAdLoad(long) (AdSlot.java:118) 07-07 02:45:29.072 7593-7593/? I/art: at void com.amazon.device.ads.AdLoadStarter.loadAds(int, com.amazon.device.ads.AdTargetingOptions, com.amazon.device.ads.AdSlot[]) (AdLoadStarter.java:94) 07-07 02:45:29.072 7593-7593/? I/art: at boolean com.amazon.device.ads.AdLayout.loadAd(com.amazon.device.ads.AdTargetingOptions) (AdLayout.java:764) 07-07 02:45:29.072 7593-7593/? I/art: at void com.bozon.shubh.pen.bozonink.MainActivity.onCreate(android.os.Bundle) (MainActivity.java:22) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.Activity.performCreate(android.os.Bundle) (Activity.java:6705) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.Instrumentation.callActivityOnCreate(android.app.Activity, android.os.Bundle) (Instrumentation.java:1119) 07-07 02:45:29.072 7593-7593/? I/art: at android.app.Activity android.app.ActivityThread.performLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent) (ActivityThread.java:2599) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.handleLaunchActivity(android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:2707) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.-wrap12(android.app.ActivityThread, android.app.ActivityThread$ActivityClientRecord, android.content.Intent, java.lang.String) (ActivityThread.java:-1) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread$H.handleMessage(android.os.Message) (ActivityThread.java:1460) 07-07 02:45:29.072 7593-7593/? I/art: at void android.os.Handler.dispatchMessage(android.os.Message) (Handler.java:102) 07-07 02:45:29.072 7593-7593/? I/art: at void android.os.Looper.loop() (Looper.java:154) 07-07 02:45:29.072 7593-7593/? I/art: at void android.app.ActivityThread.main(java.lang.String[]) (ActivityThread.java:6077) 07-07 02:45:29.072 7593-7593/? I/art: at java.lang.Object java.lang.reflect.Method.invoke!(java.lang.Object, java.lang.Object[]) (Method.java:-2) 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit$MethodAndArgsCaller.run() (ZygoteInit.java:865) 07-07 02:45:29.072 7593-7593/? I/art: at void com.android.internal.os.ZygoteInit.main(java.lang.String[]) (ZygoteInit.java:755) 07-07 02:45:29.220 7593-7642/com.bozon.shubh.pen.bozoninkpen I/Adreno: QUALCOMM build : c6f59fa, Ie9c95840c4 Build Date : 06/16/17 OpenGL ES Shader Compiler Version: XE031.09.00.03 Local Branch : Remote Branch : refs/tags/AU_LINUX_ANDROID_LA.UM.5.5.R1.07.00.00.269.021 Remote Branch : NONE Reconstruct Branch : NOTHING 07-07 02:45:29.227 7593-7642/com.bozon.shubh.pen.bozoninkpen I/OpenGLRenderer: Initialized EGL, version 1.4 07-07 02:45:29.227 7593-7642/com.bozon.shubh.pen.bozoninkpen D/OpenGLRenderer: Swap behavior 1 07-07 02:45:29.268 7593-7593/com.bozon.shubh.pen.bozoninkpen W/art: Before Android 4.1, method int android.support.v7.widget.ListViewCompat.lookForSelectablePosition(int, boolean) would have incorrectly overridden the package-private method in android.widget.ListView 07-07 02:45:29.301 7593-7649/com.bozon.shubh.pen.bozoninkpen W/cr_CrashFileManager: /data/user/0/com.bozon.shubh.pen.bozoninkpen/cache/WebView/Crash Reports does not exist or is not a directory 07-07 02:45:29.333 7593-7610/com.bozon.shubh.pen.bozoninkpen I/DpmTcmClient: RegisterTcmMonitor from: com.android.okhttp.TcmIdleTimerMonitor 07-07 02:45:29.336 7593-7610/com.bozon.shubh.pen.bozoninkpen D/NetworkSecurityConfig: No Network Security Config specified, using platform default
