HidetakaOkamoto avatar image
HidetakaOkamoto asked
ask-cli shows `ExperimentalWarning: The fs.promises API is experimental`
Expected Behavior
All command should not show any warning.
<code>$ ask util
  Usage: ask-util
  $ ask util [command]
  Util functions to manage the life cycle of Alexa Skills.
  Options:
    -h, --help                     output usage information
  Commands:
    generate-lwa-tokens [options]  generates LWA tokens from 3p clientId and clientCredentials
Current Behavior
ask-cli shows ExperimentalWarning at first line.
<code>$ ask util
(node:35788) ExperimentalWarning: The fs.promises API is experimental
  Usage: ask-util
  Options:
  Commands:
Possible Solution
I think we should update fs-extra package to 6.0.1 or later.
jprichardson/node-fs-extra#578 (comment)
I've fixed issue by following actions.
<code>$ cd /usr/local/lib/node_modules/ask-cli
$ npm i -S fs-extra@6.0.1
$ ask util
  Usage: ask-util
  Options:
  Commands:
Steps to Reproduce (for bugs)
<code>$ npm i -g ask-cli
$ ask util
  Usage: ask-util
  Options:
  Commands:
Context
I wanna to run some CI tests, but for now, assertion does not work well.
Because the warning shows at first line.
test code
<code>const assert = require('power-assert')
const { spawn } = require('child_process')
describe('test by ask-cli', () => {
  it('exit code should be zero', (done) => {
    var cli = spawn('ask', [
      'api', 'get-model', '-s', 'amzn1.ask.skill.d7d6176c-ab76-4e4c-b5ee-81366c4cd223'
    cli.stdout.on('data', function (data) {
      assert.deepEqual(data.toString(), {})
      done()
    cli.stderr.on('data', function (err) {
      assert.deepEqual(err.toString(), {})
      done()
    cli.stdin.write('testing')
test result
<code>  1) test by ask-cli
       exit code should be zero:
     Uncaught AssertionError [ERR_ASSERTION]: '(node:35815) ExperimentalWarning: The fs.promises API is experimental\n' deepEqual {}
Your Environment
<code>$ ask -v
1.4.0
Node.js and NPM Info
  • Node.js version used for development:
  • NPM version used for development:
<code>$ node -v
v10.1.0
$ npm -v
5.6.0
Kindly regards.
ask cli
Hello and thank you for posting in our forums.
I tried to reproduce the issue you mentioned, but wasn't able to:
[~]$ ask util
Usage: ask-util
Options:
Commands:
Here is the environment where it was tested:
[~]$ ask -v
1.4.0
[~]$ node -v
v10.5.0
[~]$ npm -v
6.1.0
Regards,
Barry
