GS avatar image
GS asked ·
DynamoDB trigger shows PROBLEM: Function call failed.
I have a Lambda function that reads the data from DynamoDB table. When I invoke the skill, sometimes the skill does not respond and the DynamoDB trigger shows PROBLEM: Function call failed. This has been happening consistently with interruptions at different responses. Is there a solution or work around? Thank you.
alexa skills kitlambdadynamodb
Amazon_Bernardo Bezerra answered ·
Hello GS and thank you for your post.
I understand you are having issues with the lambda code you are developing for your skill. However, the most appropriate forum to look for answers regarding DynamoDB and lambda is the AWS Forum.
Regards,
Barry
