MerryOscar_Opearlo avatar image
MerryOscar_Opearlo asked
Is Entity Resolution JSON Present in a CanFulfillIntentRequest
Is Entity Resolution JSON Present in a CanFulfillIntentRequest ?
In the examples in the docs the JSON structure of the intent looks like this:
<code>"intent":{"name":"MyNameIsIntent","slots":{"name":{"name":"name","value":"Jeff"}}},
Which does not include any entity resolution information.
Ideally I would want to use entity resolution info to determine whether we can understand and fulfill the request - will this information be available in these request types?
alexa skills kitdialog directivecanfulfillintentrequest
Anand@Amazon avatar image
Anand@Amazon answered
Hello MerryOscar,
Thanks for posting !!!
This feature is not supported as of now but can be a good feature request which you can raise here to product team for future updates.
D. Daniels avatar image
D. Daniels answered
It appears that the Name-free interaction canFulfillIntent feature does use entity resolution to set default values for slot canUnderstand/canFulfill.
https://developer.amazon.com/docs/custom-skills/understand-name-free-interaction-for-custom-skills.html#canunderstand-management
Default values using the entity resolution implementation from the Alexa Skills Kit
The Alexa Skills Kit provides entity resolution. If your skill uses the entity resolution data to understand slot values, the default value for canUnderstand is as follows.
  • Set canUnderstand = "YES" if entity resolution successfully resolves slot value.
  • Set canUnderstand = "NO" if entity resolution does not resolve slot value.
If you want, you can overwrite the default.
