Hi, I followed the instructions here: https://github.com/alexa/skill-sample-nodejs-fact-in-skill-purchases/issues/6, but I'm getting the following error in the cloud log. What does it mean and how can I correct it?
Unable to import module 'index': Error
at Function.Module._resolveFilename (module.js:547:15)
at Function.Module._load (module.js:474:25)
at Module.require (module.js:596:17)
at require (internal/module.js:11:18)
at Object. (/var/task/index.js:6:15)
at Module._compile (module.js:652:30)
at Object.Module._extensions..js (module.js:663:10)
at Module.load (module.js:565:32)
at tryModuleLoad (module.js:505:12)
at Function.Module._load (module.js:497:3)
I'm also seeing the following error in my terminal:
Error(s) found in the deploy setting for the following in-skill product(s):
(Please restore the missing file or modify skill configuration file .ask/config to fix the deploy setting)
Missing file: [ID] undefined [FILE] isps/entitlement/Entitlement_Template.json
