newuser-a5b653f0-b63b-473e-9db5-166ddf2febc3 avatar image
Alexa Skill failing when calling a lambda function
Getting error - Region is N Virginia-
Calling the Invoke API failed with message: We currently do not have sufficient capacity in the region you requested. Our system will be working on provisioning additional capacity. You can avoid getting this error by temporarily reducing your request rate. How to fix it?
alexa skills kitlambda
Brian@Amazon avatar image
Brian@Amazon answered
Hello. This issue should only last briefly, and then testing or invoking the skill should subsequently work properly. Let us know if this is not the case.
