newuser-d0d01ca6-33fa-4378-bc7a-054e5c60d5a4 avatar image
SpeechletRequestStreamHandler with Speechlet or SkillStreamHandler with RequestHandler
The documentation at https://developer.amazon.com/docs indicates that skills deployed to lambda should be built using a SpeechletRequestStreamHandler and Speechlet (com.amazon.speech.speechlet.lambda.SpeechletRequestStreamHandler and com.amazon.speech.speechlet.Speechlet). However, the newest code in the SDK located at https://github.com/alexa/alexa-skills-kit-sdk-for-java/ uses subclasses of SkillStreamHandler and RequestHandler (com.amazon.ask.SkillStreamHandler and com.amazon.ask.dispatcher.request.handler.RequestHandler) to implement a skill deployed to lambda. Speechlet is not used.
What is the recommended or preferred way of doing this? And, if using SkillStreamHandler and RequestHandler, what class should be listed in the Handler field in the Lambda function configuration?
alexa skills kitlambdasdkjava
Jenn@amazon avatar image
Jenn@amazon answered
Thanks for reporting this. I've opened a ticket with our Docu Team to updated the instructions.
Looking in the Developing Your First Skill section of the Java SDK Wiki, it appears the correct class is the SkillStreamHandler.
jothi avatar image
jothi answered
seems like the documentation is not fixed yet. i got confused when i read the doc too.... luckily i found this answer...
