When I attempt to host an IP camera on a .CAM domain address (using port 443), the Echo Show/FireTV never attempt to connect to the camera endpoint. It's not event attempting to connect the socket to validate the TLS/SSL certificate. It's almost like .CAM domain name is blacklisted? I have tried with 2 .CAM domains and no luck with either. If I simply test using a .IO domain the connection on port 443 is established and the TLS attempt to validate.
Is there a reason we are not able to use .CAM domains?
Thank You,
Robert
