Stack Overflow: A New Way for Developers to Get Support for Alexa
Now you can find Alexa-specific tags and topics in the AWS Collective on Stack Overflow. Ask questions and get help from badged experts and the Alexa developer community!
slivings99 avatar image
slivings99 asked
Example phrase does not follow the right launch pattern
I am having difficulty in understanding why the English (US) Store Preview page is flagging my example phrase with this warning, "Your example phrase, 'Alexa, Ask X to Y' does not follow the right launch pattern. X is my invocation name and Y is a specific sample utterance with two slots that follows the pattern "move A to B" where A and B are the two slots with valid values.
My skill is in beta and works fine with the example phrase being used in practice.
alexa skills kitcertificationinvocation nameutterances
Reshma avatar image
Reshma answered
Hi. I am facing same issue. Did you get any solution for the above?
Anand@Amazon avatar image
Anand@Amazon answered
Hello Slivings99,
Thanks for posting !!!
Please provide skill id for further debugging.
slivings99 avatar image slivings99 commented ·
amzn1.ask.skill.a1273b7d-671d-43e4-aa3e-048be1ec6bdc
Harper avatar image
Harper answered
It looks like your example phrase uses "Flat Position" but your slot type for MemoryPosition doesn't have this value, and since your sample utterance uses this slot type, it isn't matching your example phrase. Try adding "Flat Position" as a slot value for that slot type and see if that resolves the error.
darth_gera avatar image
darth_gera answered
just try out begin,ask,loadand see if it runs
newuser-393b81a8-e7ef-480b-8864-2f40a1dcc4bc avatar image
newuser-393b81a8-e7ef-480b-8864-2f40a1dcc4bc answered
same issue
Rokas avatar image Rokas commented ·
What example phrases are failing for you? I suggest you to post your skill id or provide those example phrases, so that someone from amazon could help you.
