newuser-1385ae83-500a-41cf-bf34-99342bd3f87c avatar image
Virtual device is unresponsive
I have written custom skill which discovers virtual devices. When I run it on emulator is returns positive acknowledgement 'OK'. But when I try to access the current status of that device through alexa app it shows device is unresponsive and always show device is off.
lambda Function :
exports.handler = function (request, context) {
    if (request.directive.header.namespace === 'Alexa.Discovery' && request.directive.header.name === 'Discover') {
        log("DEBUG:", "Discover request",  JSON.stringify(request));
        handleDiscovery(request, context, "");
    else if (request.directive.header.namespace === 'Alexa.PowerController') {
        if (request.directive.header.name === 'TurnOn' || request.directive.header.name === 'TurnOff') {
            log("DEBUG:", "TurnOn or TurnOff Request", JSON.stringify(request));
            handlePowerControl(request, context);
    function handleDiscovery(request, context) {
        var payload = {
            "endpoints":
                    "endpointId": "6f31dc57-d033-4cbd-8020-6bbb516bcab",
                    "manufacturerName": "Smart Device Company",
                    "friendlyName": "Bedroom Outlet",
                    "description": "Smart Device Switch",
                    "displayCategories": ["LIGHT"],
                    "isReachable": true,
                    "cookie": {
                        "key1": "arbitrary key/value pairs for skill to reference this endpoint.",
                        "key2": "There can be multiple entries",
                        "key3": "but they should only be used for reference purposes.",
                        "key4": "This is not a suitable place to maintain current endpoint state."
                    "capabilities":
                            "type":"AlexaInterface",
                            "interface":"Alexa.ColorTemperatureController",
                            "version":"3",
                            "properties":{
                                "supported":[
                                  "name":"colorTemperatureInKelvin"
                            "proactivelyReported":true,
                            "retrievable":true
                            "type": "AlexaInterface",
                            "interface": "Alexa.PowerController",
                            "version": "3",
                            "properties": {
                            "supported": [ {
                                "name": "powerState"
                            "proactivelyReported": true,
                            "retrievable": true
                            "interface":"Alexa",
                            "version":"3"
                            "interface":"Alexa.ColorController",
                            "version":"3",
                            "properties":{
                                "supported":[
                                    "name":"color"
                            "retrievable":true
        var header = request.directive.header;
        header.name = "Discover.Response";
        log("DEBUG", "Discovery Response: ", JSON.stringify({ header: header, payload: payload }));
        context.succeed({ event: { header: header, payload: payload } });
    function log(message, message1, message2) {
        console.log(message + message1 + message2);
    function handlePowerControl(request, context) {
        // get device ID passed in during discovery
        var requestMethod = request.directive.header.name;
        // get user token pass in request
        var requestToken = request.directive.endpoint.scope.token;
        var powerResult;
        if (requestMethod === "TurnOn") {
            // Make the call to your device cloud for control
            // powerResult = stubControlFunctionToYourCloud(endpointId, token, request);
            powerResult = "ON";
       else if (requestMethod === "TurnOff") {
            // Make the call to your device cloud for control and check for success
            powerResult = "OFF";
        var contextResult = {
            "properties": [{
                "namespace": "Alexa.PowerController",
                "name": "powerState",
                "value": powerResult,
                "timeOfSample": "2017-09-03T16:20:50.52Z", //retrieve from result.
                "uncertaintyInMilliseconds": 500
        var tok = request.directive.endpoint.scope.token;
        var endpointResult = {
            "scope":  {
                "type": "BearerToken",
                "token": tok
        var responseHeader = request.directive.header;
        responseHeader.name = "Response";
        responseHeader.namespace= "Alexa";
        responseHeader.messageId = responseHeader.messageId + "-R";
        var response = {
            context: contextResult,
            event: {
                header: responseHeader,
                endpoint: endpointResult,
                payload: {}
        log("DEBUG", "Alexa.PowerController ", JSON.stringify(response));
        context.succeed(response);
test - event :
  "directive": {
    "header": {
      "name": "TurnOn",
      "payloadVersion": "3",
      "messageId": "1bd5d003-31b9-476f-ad03-71d471922820",
      "correlationToken": "dFMb0z+PgpgdDmluhJ1LddFvSqZ/jCc8ptlAKulUj90jSqg=="
    "endpoint": {
      "scope": {
        "token": "access-token-from-1111"
      "endpointId": "demo_id",
      "cookie": {}
    "payload": {}
Response :
Response:
  "context": {
    "properties": [
        "value": "ON",
  "event": {
    "header": {
      "namespace": "Alexa",
      "name": "Response",
      "messageId": "1bd5d003-31b9-476f-ad03-71d471922820-R",
    "endpoint": {
      "scope": {
    "payload": {}
alexa skills kitalexa smart homelambdaresponsedevice discovery
Anand@Amazon avatar image
Anand@Amazon answered
Hello there,
Please provide skill id for further debugging.
2 comments
I would also like some help with this issue as my virtual devices are all unresponsive
Skill ID: amzn1.ask.skill.c06eba03-0506-4486-9efa-e6aecd324405
Hello there,
For this issue I will suggest to add "Alexa.EndpointHealth" interface also as capability which represent information about overall health of a smart home device.
Please also send "stateReport" for ReportState event and also send ChangeReport event to Alexa event gateway to get latest endpoint state.
Check this link to learn more about EndpointHealth interface.
