newuser-1385ae83-500a-41cf-bf34-99342bd3f87c avatar image
How to use Sonoff smart wifi switch in smart home custom skill?
How to use sonoff wifi smart switch with smart home custom skill? I have bought wifi smart switch and wrote custom skill which discovers devices and turn them ON/OFF. But alexa is not discovering this smart wifi switch. Is device Id same as appliance Id which we need to mention in custom skill? Device=Smart WIFI smart switch Sonnoff
Please help where I am going wrong as it still showing device is unresponsive.
screenshot: Screenshot
lambda code :
exports.handler = function (request, context) {
    if (request.directive.header.namespace === 'Alexa.Discovery' && request.directive.header.name === 'Discover') {
        log("DEBUG:", "Discover request",  JSON.stringify(request));
        handleDiscovery(request, context, "");
    else if (request.directive.header.namespace === 'Alexa.PowerController') {
        if (request.directive.header.name === 'TurnOn' || request.directive.header.name === 'TurnOff') {
            log("DEBUG:", "TurnOn or TurnOff Request", JSON.stringify(request));
            handlePowerControl(request, context);
    function handleDiscovery(request, context) {
        var payload = {
            "endpoints":
                    "endpointId": "100019df84",
                    "manufacturerName": "Smart Device Company",
                    "friendlyName": "Bedroom Outlet",
                    "description": "Smart Device Switch",
                    "displayCategories": ["LIGHT"],
                    "cookie": {
                        "key1": "arbitrary key/value pairs for skill to reference this endpoint.",
                        "key2": "There can be multiple entries",
                        "key3": "but they should only be used for reference purposes.",
                        "key4": "This is not a suitable place to maintain current endpoint state."
                    "capabilities":
                          "type": "AlexaInterface",
                          "interface": "Alexa",
                          "version": "3"
                            "interface": "Alexa.PowerController",
                            "version": "3",
                            "properties": {
                                "supported": [{
                                    "name": "powerState"
                                "proactivelyReported": true,
                                 "retrievable": true
        var header = request.directive.header;
        header.name = "Discover.Response";
        log("DEBUG", "Discovery Response: ", JSON.stringify({ header: header, payload: payload }));
        context.succeed({ event: { header: header, payload: payload } });
    function log(message, message1, message2) {
        console.log(message + message1 + message2);
    function handlePowerControl(request, context) {
        // get device ID passed in during discovery
        var requestMethod = request.directive.header.name;
        // get user token pass in request
        var requestToken = request.directive.endpoint.scope.token;
        var powerResult;
        if (requestMethod === "TurnOn") {
            // Make the call to your device cloud for control
            // powerResult = stubControlFunctionToYourCloud(endpointId, token, request);
            powerResult = "ON";
       else if (requestMethod === "TurnOff") {
            // Make the call to your device cloud for control and check for success
            powerResult = "OFF";
        var contextResult = {
            "properties": [{
                "namespace": "Alexa.PowerController",
                "name": "powerState",
                "value": powerResult,
                "timeOfSample": "2017-09-03T16:20:50.52Z", //retrieve from result.
                "uncertaintyInMilliseconds": 500
        var endpointResult = {
            "scope":  {
                "type": "BearerToken",
                "token": "access-token-from-Amazon"
        var responseHeader = request.directive.header;
        responseHeader.name = "Response";
        responseHeader.namespace= "Alexa";
        responseHeader.messageId = responseHeader.messageId + "-R";
        var response = {
            context: contextResult,
            event: {
                header: responseHeader,
                endpoint: endpointResult,
                payload: {}
        log("DEBUG", "Alexa.PowerController ", JSON.stringify(response));
        context.succeed(response);
skillalexa smart homelambdasmart homedevice discovery
Brian@Amazon avatar image
Brian@Amazon answered
Hi. I don't quite understand what issue you are having. Do you have issues controlling or discovering the skill you've built for this purpose?
If you are having issues running discovery, when you run discovery is your lambda function triggered?
webtop avatar image
webtop answered
For anyone else that finds this: Alexa doesn't talk directly to Sonoff devices, AFAIK. You need to enable the Ewelink skill on your Alexa device first, giving her the ability to talk to Sonoff devices via the Ewelink app.
I have a number of Sonoff devices and Alexa controls them just fine, with Ewelink
