Abdelilah Lbardi avatar image
Abdelilah Lbardi asked
How to identify the asked question in the skill backend?
I am working on a simple "True or False" with a custom skill development.
Giving an example with the following scenario, I can not identify the question that I ask to the user to define if it's true or not.
U: Alexa, start "true or false facts"
A: Hello there.
U: Give me a random question
A: Jodie Foster won her first Oscar for her role in the movie TaxiDriver?
U: this is not true.
A: Bravo! Good answer. Jodie Foster was nominated for her role in Taxi Driver,but she did not win the statuette. Want an other question?
A: yes
I can not define how to keep the dialog continuity and the giving answer is related to what question.
Thanks a million.
intentshow-toask cliinteraction model
TheStrandedStarfish avatar image
TheStrandedStarfish answered
Easiest way is to use session attributes. You store this at the upper level of the response in a field named sessionAttributes.
        'version': '1.0',
        'sessionAttributes': sessionAttributes,
        'response': speechletResponse
You can then retrieve them in the next JSON Request sent to you in a field called attributes in the session
  "version": "string",
  "sessionAttributes": {
    "key": "value"
2 comments
Abdelilah Lbardi avatar image Abdelilah Lbardi commented ·
Thanks a million for your answer. I just found about it in the documentation.
A.
TheStrandedStarfish avatar image TheStrandedStarfish Abdelilah Lbardi commented ·
BTW, apparently if you use NodeJS, there is a simple way to do this:
this.attributes.<key> = <value>
Info here: https://developer.amazon.com/blogs/alexa/post/2279543b-ed7b-48b4-a3aa-d273f7aab609/alexa-skill-recipe-using-session-attributes-to-enable-repeat-responses
