I am using tableau-api in node module of lamda function. But unfortunately this module is not able to import in my lambda function. module is available in NPM site and i followed the documentation properly, but nothing could help me.
for example :
'use strict'; const Alexa = require("alexa-sdk"); var tab = require("tableau-api"); exports.handler = function(event, context, callback) { const alexa = Alexa.handler(event, context); alexa.registerHandlers(handlers); alexa.execute(); }; const handlers = { 'LaunchRequest': function() { this.emit('SayHello'); }, 'HelloWorldIntent': function() { this.emit('SayHello'); } };
- When i test this code error is showing.
"errorMessage": "Cannot find module 'tableau-api'", "errorType": "Error", "stackTrace": [ "Function.Module._load (module.js:474:25)", "Module.require (module.js:596:17)", "require (internal/module.js:11:18)", "Object.<anonymous> (/var/task/index.js:3:11)", "Module._compile (module.js:652:30)", "Object.Module._extensions..js (module.js:663:10)", "Module.load (module.js:565:32)", "tryModuleLoad (module.js:505:12)", "Function.Module._load (module.js:497:3)"
