PreSchool Teacher avatar image
PreSchool Teacher asked
Trageting Devices
We have done a tablet app 1024by600 and 1280by800 resolutions (7 and 10.1 inch) app and want to exclude all smaller devices. Does the manifest file control which devices are select in Amazon? Should our manifest contain something like or this... [     ...
amazon appstore
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi PreSchool Teacher, Thank you for your post. Amazon App Store does not bother about "supports-screens" manifest parameters to target an apk for a device. Instead we give developers freedom to select devices for their builds. This feature enables you to take a single app and target specific APKs to specific Amazon devices, as well as target a single, general APK that covers all other non-Amazon Android devices. If you would like to take advantage of the Device Targeting feature by building new APKs for the Fire HD and new Fire, you will still need to upload an appropriate APK for the Fire (1st Generation) and non-Amazon Android devices. If you only add APKs (binaries) for the new Amazon devices to your app update, you will no longer be supporting the other device types for your app—customers on Fire (1st Generation) and non-Amazon android devices will not be able to download your app in the store. Please be sure your updated APKs target all device types. You may use any combination of APKs to target any combination of device types. Example: 4 APKs for 4 device types (Kindle Fire, Fire HD, Original Fire, general android) 3 APKs for 4 device types 2 APKs for 4 device types 1 APK for 4 device types 1 APK for 2 device types Ect… Device Targeting currently allows for up to 4 individual APKs that can target non-Amazon Android devices, Original Fire, Fire, and Fire HD 7”. We will soon add the capability to add a 5th APK for Fire HD 8.9”. Please be mindful of versionCode and versionName requirements when building your APKs: https://developer.amazon.com/help/faq.html#DeviceTargeting For more information please refer below link, https://developer.amazon.com/post/Tx2IQ6FUR1ASHFK/How-To-Use-Amazon-Device-Targeting.html
If you want to upload multibinary the following information should help you for better understanding. VersionName must be the same for each APK within an instance of an app (format of X.X.X where X is an integer). VersionCode must be different for each APK within an instance of an app (format of X where X is an integer). It will help your tracking if you increment your versionCode when submitting an app update, but you may use the same X as a previous versionCode if you desire. Ex: Manifest snippet: manifest xmlns:android=" http://schemas.android.com/apk/res/android" package="com.amazon.sample.buttonclicker" android:versionCode="100" android:versionName="1.0.0" uses-sdk android:minSdkVersion="10" / APK Naming Best Practices as per d.android: An APK that requires a higher API level must usually have a higher version code. For example, if you create two APKs to support different API levels, the APK for the higher API levels must have the higher version code. This ensures that if a device receives a system update that then qualifies it to install the APK for higher API levels, the user receives a notification to update the app. You should also consider how the order of version codes might affect which APK your users receive either due to overlap between coverage of different APKs or future changes you might make to your APKs. For example, if you have different APKs based on screen size, such as one for small - normal and one for large - xlarge, but foresee a time when you will change the APKs to be one for small and one for normal - xlarge, then you should make the version code for the large - xlarge APK be higher. That way, a normal size device will receive the appropriate update when you make the change, because the version code increases from the existing APK to the new APK that now supports the device.
dadokan avatar image
dadokan answered
Hi Sujoy, is the other way around also possible? E.g. 1 APK for all Kindle devices & other devices 3 Different APK's for non Amazone devices (requirements are set in the manifest) We have different APK's for supporting different GPU's. Message was edited by: dadokan
Hi Dadokan, 1 APK for all Kindle devices & other devices is possible. But you can not have 3 APKs for non Amazon at this moment.
