KaptainKoffee avatar image
KaptainKoffee asked
Alexa flash briefing says "From...blah blah" then plays no content.
So I've got my content hosted in an amazon s3 bucket set to public read permissions. I've gone over the setup documentation many times. I've tried to make sure my audio file hits the recommend loudness and bitrate many times. I can't for the life of me figure out why my audio files won't play. I've downloaded a couple test files from other users and they work no problem.
Please see my json and audio file I'm trying to use as a test.
I've made sure my audio file loudness is between the recommended -14 to -19db with no loud peaks above -2db
https://s3.amazonaws.com/kaptainkoffee-flashbriefing/AlexaJson.json
https://s3.amazonaws.com/kaptainkoffee-flashbriefing/AlexaTest.mp3
What I hear from Alexa via echosim.io is "This is your flash briefing from KaptainKoffee test". Then I hear nothing, then Alexa says "that is all from your flash briefing".
So I know it's trying to play something, or at least looking for something.
Here is a test file I found on GitHub, that if I put the URL in my json file, alexa is able to play. I don't know what is different from my audio file:
https://raw.githubusercontent.com/okofish/flashtest/master/feeds/multiaudio-1.mp3
Please help! :-)
alexa skills kitflash briefing
KaptainKoffee avatar image KaptainKoffee commented ·
Edit: 16000 sample rate is horrible... Bumped that up to 48khz with an export of 256kb bitrate
Pete S avatar image
Pete S answered
Neither of your links to your content work, they return the following error:
<Error>
<Code>NoSuchBucket</Code>
<Message>The specified bucket does not exist</Message>
<BucketName>kaptainkoffee-flashbriefing</BucketName>
<RequestId>ED0559DBAC98F520</RequestId>
<HostId>
vKIT4sLi88VSdQtcvs/wuTZiX1X2BiL6h5s8ESfuh7UzJJMKtMb52szKMj/9RetVGqX/prcvK4I=
</HostId>
</Error>
Are you sure your links are correct and your bucket permissions are set correctly?
