Robert Chapin avatar image
Robert Chapin asked
How to see native resolution in emulator?
When I try to create a Kindle Fire HD 7 emulator, it appears in a very small window. The only improvement was when I turned off the default skin and set a resolution of 800 x 1280. In that case it created a window sized 608 x 972. So essentially I have no idea what the image quality is like on the real device. Is there a way to create the 800 x 1280 emulator window on a 1280 x 1024 monitor?
fire tablet
Robert Chapin answered
I figured out that with the resolution set to 800 x 1280, I can get a full size window by using the scale option at 7" and 215 dpi. When I do that, it says the scale is set to 1.00 and then it behaves as expected.
Samuel@Amazon avatar image
Samuel@Amazon answered
Robert, It is great to know that you have solved your issue. Thank you.
