Fritz avatar image
Fritz asked
Mac: No repository found at http://kindle-sdk.s3.amazonaws.com/addon.xml
MAC 10.6.8 + Eclipse Indigo with all updates. When Im trying to install the Kindle Plugins in Eclipse, I got this: No repository found at http://kindle-sdk.s3.amazonaws.com/addon.xml No repository found at http://kindle-sdk.s3.amazonaws.com/addon.xml
fire tablet
Tim@Amazon avatar image
Tim@Amazon answered
Fritz, Based on the error you reported, it looks like you may be attempting to add our addon site as an Eclipse plugin update site? Instead of through Eclipse, the Kindle Fire emulator add-ons are installed through the Android SDK Manager. In the Setting Up Your Development Environment page at: https://developer.amazon.com/sdk/fire/setup.html There are instructions to get the Android SDK Manager as well as adding our addon.xml site to it. Tim
Fritz avatar image
Fritz answered
I did it as described, but its not working. Everytime the same error messsage.
Fritz avatar image
Fritz answered
Ok, did it. "In the Android SDK Manager window, from the Tools menu, click Manage Add-on Sites" Before this I've tried it like the normal way over help->install new software
Samuel@Amazon avatar image
Samuel@Amazon answered
Yes, you need to add it as "Add-on" site instead of "Repository". It's great to know that you solved it. Please let us know if you face any issue. Thank you.
A. Khan avatar image
A. Khan answered
The question is old but I am facing the same issue and can't seem to find the tools menu when Android SDK manager is visible and can't we post screen shots i.e. images in here ?
Sujoy@Amazon avatar image
Sujoy@Amazon answered
Hi, The add on site mentioned contains basically the USB driver for Kindle tablets which is needed in Windows only, in Mac Kindle could be connected directly with out any explicit driver. Please note that above add on site used to contain the links for Kindle Emulators also what are discontinued to be supported now.
