C. Ata avatar image
C. Ata asked
Accelerometer in 1st gen?
Hi All, Which devices don't have an accelerometer? Just the 1st gen? All I've found is this document, but it doesn't detail hardware: https://developer.amazon.com/sdk/fire/specifications.html Thanks, -Chad
fire tablet
Samuel@Amazon avatar image
Samuel@Amazon answered
Hi Chad, In Android 2.3 (Gingerbread), hardware acceleration is not available. But in later versions of Android, this has been made available to increase performance of application graphics. To do so, your app must specify API level 11 as a minimum OS. Hope this information helps you. Thank you.
C. Ata avatar image
C. Ata answered
Hi Samuel, Thanks for the quick response, but I'm asking about the accelerometer - for tilt controls. Does the 1st gen Kindle have an accelerometer? Thanks
Dixith@Amazon avatar image
Dixith@Amazon answered
Hi, KindleFire 1st generation device builds on Android 2.3.3 using API level 10 and does not have an accelerometer . Please look into the below link for more information on Kindle Fire specifications. https://developer.amazon.com/sdk/fire/specifications.html
C. Ata avatar image
C. Ata answered
Ah ok, thank you for confirming this. Note: that document doesn't mention accelerometer anywhere. -Chad
