Abu Obeida@Amazon avatar image
Abu Obeida@Amazon asked
Speed Up API Integration Using the Amazon Mobile App SDK Eclipse Plugin
Hi, For those of you who are just starting to use Amazon APIs such as In App Purchasing and Maps, I am pleased to bring to your attention the new Amazon Mobile App SDK Eclipse Plugin (beta), which allows you to rapidly and reliably integrate Amazon APIs into your Android projects, speeding up development and cutting down on project setup time. Benefits of using the Amazon Mobile App SDK Eclipse Plugin: - Easy to use: Developers have indicated that it is surprisingly fast to deploy and use the plugin. The deployment of this tool follows the typical Eclipse plugin download and installation experience and does not require a new usage paradigm. - Gives you control of APIs and versions: The plugin allows you to use the latest version of the APIs in the Amazon Mobile App SDK that you have on your system and will alert you if your project is using an older version of the APIs. - Works for all apps and games: The plugin helps you to quickly develop any Android app that you plan to offer via the Amazon marketplace, including Kindle Fire tablets and Android smartphones. Click here to learn how to install the Amazon Mobile App SDK Eclipse Plugin. https://developer.amazon.com/sdk/fire/eclipse-plugin.html Take it for a spin, add it to your toolbox, and then tell us what you think by completing this brief survey. http://www.surveymonkey.com/s/ZPMJX5C We welcome your feedback and appreciate learning what more we can do to help increase your productivity.
fire tablet
