newuser-6af715bc-85cd-425f-8053-b068a5512e93 avatar image
Google AdMob Ads Not Functioning
I submitted my android apps through the Amazon store and I noticed that the AdMob ads are not working. The ads work fine through the Play Store and App Store, but when playing on a Kindle, the ads do not appear (banner, interstitial, rewarded).
I've been unable to find documentation indicating as to why this is a problem, but I assume there must be something that needs to be updated to function on the Amazon Store.
Any help would be most appreciated.
Thanks,
Theron
app submission and updatesandroid
2 comments
Hi Theron,
I am able to test AdMob on a Fire HD 8 running Fire OS version 5.6.0.1.
How are you adding the AdMob SDK to your project?
私は同じ問題を抱えています。
AdMobテストユニットは機能しますが、製品ユニットは機能しません。
私はUnityEngineのAdMobPluginを使用しています。
Fire OSバージョン5.3.6.4を実行しているFire 7でAdMobをテストします
newuser-d07dc316-0eea-452c-844d-7a909bb8ce6f avatar image
newuser-d07dc316-0eea-452c-844d-7a909bb8ce6f answered
I have the same problem.
The AdMob test unit works, but the product unit does not work.
I am using UnityEngine 's AdMobPlugin.
I test AdMob on a Fire 7 running Fire OS version 5.3.6.4
newuser-0cd79c41-32bb-4264-9c3c-54f999a6bca1 avatar image
newuser-0cd79c41-32bb-4264-9c3c-54f999a6bca1 answered
If you are trying to update app and then adding AdMob ads then this issue will come.
As in new update you will need to authenticate the updated app though it won't show you ads on your app if you update it.
You will need to do some stuff to make is visible.
newuser-c6b73c7e-ccd9-4c73-9559-c332e9bf2e49 avatar image
newuser-c6b73c7e-ccd9-4c73-9559-c332e9bf2e49 answered
I seem to have the same exact problem. Just following this to see if anyone has information, so far I have none.
I create new AppId and UnitId but it does not work.
Those installed with adb will work.
Those installed in the Amazon store will not work.
Same problem here; been working with someone from AdMob and was told I have to submit this:
https://support.google.com/admob/contact/android_APK_submission
But I did that a week ago and still 0% match rate...
Ali Wayne avatar image
Ali Wayne answered
