Thomas Pleiter avatar image
Thomas Pleiter asked
Gamepad virtual keyboard
Hello, after a small update of the Hybrid App the app submit failed through an missing function of the gamepad (The update don't change anything of the program code !?). With the remote Controller the virtual keyboard open, when you navigate to an input field. With the gamepad you can navigate from input to input field, but the virtual keyboard don't open. In the FAQ( https://developer.amazon.com/public/solutions/platforms/webapps/faq , Q: Can I launch the virtual keyboard and tell when text has been submitted?) there are the information "The virtual keyboard appears when the user presses the Select button on an text input field." At the Controller Guidelines ( https://developer.amazon.com/public/solutions/devices/fire-tv/docs/controller-behavior-guidelines ) the "Select" Button from Remote Controller is similar to "A" Button from Controller. I check this with the keyCode and this is right. Why do the virtual keyboard not open when i navigate to the input field and press the "A" Button? How can i fix that?
fire tvsubmission testing distribution
