yoshi avatar image
yoshi asked
Amazon Drive tempLink error message "Nonce ... doesn't map to object"
I've been playing with Amazon Drive API and I encountered a problem with the tempLinks.
I have a folder with video files, and I list the files in the folder using the API and with tempLink = 'true', and it works as expected. However sometimes, the tempLink generated for the video returns an error "Nonce ... doesn't map to object" (where the Nonce is the last part of the link). Usually, the video's image thumbnail asset tempLink still works even the the tempLink for the file is broken.
Trying to get the node's metadata (using /nodes/<node_id>) to generate a new tempLink can solve the issue, but sometimes the new tempLink is still broken.
It seems like for some reason some of the tempLinks are being "unmapped" and thus no longer work.
I appreciate your help!
amazon driveapi
Levon@Amazon avatar image
Levon@Amazon answered
At this time, the Cloud Drive API is closed to new developers, and is limited to those that are partnered with Amazon in an effort to provide a consistent experience when using Amazon Drive. Should this change moving forward, we will inform our developer community.
We thank you for your business and support of Cloud Drive.
Thank you,
The Amazon Drive Team
