MPCPRO avatar image
MPCPRO asked
Getting alexa to read JSON (Temperature and Humidity from arduino uno)
Hey guys.
I am really new into programming but I am trying to find a way so I can ask alexa "TemperatureHumidity" etc. I followed mostly this guide here:
https://www.hackster.io/44560/amazon-echo-read-temperature-and-humidity-from-sensor-0d9b73
But he used PHP to post his json information while my Arduino Uno with Ethernetshield is posting my temperature and humidity in json only. (Check it out here: http://mpconline.tk:1470 )
Example (incase my arduino is offline:
{,"temperature":"17.00","humidity":"33.00"}
I copied his Node.js 6.10 code to my lambda coding, but I am trying to find a way to modify it to read the json from my arduino uno. The only thing I can see I have to change is the host , path and port (which I did). Though I am still unable to get Alexa to get anything from my site. Something about:
"The remote endpoint could not be called, or the response it returned was invalid."
So I was wondering if anyone couild go through the example code I used to see if there's anything obvious I should have changed?
'use strict';
 * This sample demonstrates a simple skill built with the Amazon Alexa Skills Kit.
 * The Intent Schema, Custom Slots, and Sample Utterances for this skill, as well as
 * testing instructions are located at http://amzn.to/1LzFrj6
 * For additional samples, visit the Alexa Skills Kit Getting Started guide at
 * http://amzn.to/1LGWsLG
var http = require('http');
// --------------- Helpers that build all of the responses -----------------------
function buildSpeechletResponse(title, output, repromptText, shouldEndSession) {
    return {
        outputSpeech: {
            type: 'PlainText',
            text: output,
        card: {
            type: 'Simple',
            title: "SessionSpeechlet - " + title,
            content: "SessionSpeechlet - " + output,
        reprompt: {
            outputSpeech: {
                type: 'PlainText',
                text: repromptText,
        shouldEndSession: shouldEndSession
function buildResponse(sessionAttributes, speechletResponse) {
    return {
        version: '1.0',
        sessionAttributes,
        response: speechletResponse,
// --------------- Functions that control the skill's behavior -----------------------
function getWelcomeResponse(callback) {
    // If we wanted to initialize the session to have some attributes we could add those here.
    const sessionAttributes = {};
    const cardTitle = 'Welcome';
    const speechOutput = "Welcome to P H P o C. How can I help you?"
    // If the user either does not reply to the welcome message or says something that is not
    // understood, they will be prompted again with this text.
    const repromptText = "How can I help you?";
    const shouldEndSession = false;
    callback(sessionAttributes,
        buildSpeechletResponse(cardTitle, speechOutput, repromptText, shouldEndSession));
function handleSessionEndRequest(callback) {
    const cardTitle = 'Session Ended';
    const speechOutput = 'Thank you for trying the Alexa Skills Kit sample. Have a nice day!';
    // Setting this to true ends the session and exits the skill.
    const shouldEndSession = true;
    callback({}, buildSpeechletResponse(cardTitle, speechOutput, null, shouldEndSession));
function createTemperatureAttributes(temperature) {
    return {
        temperature: temperature
 * Read temperature in the session and prepares the speech to reply to the user.
function readTemperatureInSession(intent, session, callback) {
    const cardTitle = intent.name;
    let repromptText = '';
    let sessionAttributes = {};
    let speechOutput = '';
	var body = '';
	//Update
	var httpPromise = new Promise( function(resolve,reject){
		http.get({
			host: '192.168.1.207',
			path: '',
			port: '1470'
		}, function(response) {
			// Continuously update stream with data
			response.on('data', function(d) {
				body += d;
			response.on('end', function() {
				// Data reception is done, do whatever with it!
				console.log(body);
				resolve('Done Sending');
	httpPromise.then(
		function(data) {
			var info = JSON.parse(body);
			console.log('Function called succesfully:', data);
			sessionAttributes = createTemperatureAttributes(info.temperature);
			speechOutput = "Temperature is " + info.temperature + " degree Celsius. Humidity is " + info.humidity + " percent";
			repromptText = "Temperature is " + info.temperature + " degree Celsius. Humidity is " + info.humidity + " percent";
			console.log(speechOutput);
			callback(sessionAttributes,buildSpeechletResponse(cardTitle, speechOutput, repromptText, shouldEndSession));
		function(err) {
			console.log('An error occurred:', err);
// --------------- Events -----------------------
 * Called when the session starts.
function onSessionStarted(sessionStartedRequest, session) {
    console.log("onSessionStarted requestId=${sessionStartedRequest.requestId}, sessionId=${session.sessionId}");
 * Called when the user launches the skill without specifying what they want.
function onLaunch(launchRequest, session, callback) {
    console.log("onLaunch requestId=${launchRequest.requestId}, sessionId=${session.sessionId}");
    // Dispatch to your skill's launch.
    getWelcomeResponse(callback);
 * Called when the user specifies an intent for this skill.
function onIntent(intentRequest, session, callback) {
    console.log("onIntent requestId=${intentRequest.requestId}, sessionId=${session.sessionId}");
    const intent = intentRequest.intent;
    const intentName = intentRequest.intent.name;
    // Dispatch to your skill's intent handlers
    if (intentName === 'TemperatureHumidity') {
        readTemperatureInSession(intent, session, callback);
    } else if (intentName === 'AMAZON.HelpIntent') {
    } else if (intentName === 'AMAZON.StopIntent' || intentName === 'AMAZON.CancelIntent') {
        handleSessionEndRequest(callback);
    } else {
        throw new Error('Invalid intent');
 * Called when the user ends the session.
 * Is not called when the skill returns shouldEndSession=true.
function onSessionEnded(sessionEndedRequest, session) {
    console.log("onSessionEnded requestId=${sessionEndedRequest.requestId}, sessionId=${session.sessionId}");
    // Add cleanup logic here
// --------------- Main handler -----------------------
// Route the incoming request based on type (LaunchRequest, IntentRequest,
// etc.) The JSON body of the request is provided in the event parameter.
exports.handler = (event, context) => {
    try {
        console.log("event.session.application.applicationId=${event.session.application.applicationId}");
         * Uncomment this if statement and populate with your skill's application ID to
         * prevent someone else from configuring a skill that sends requests to this function.
        if (event.session.application.applicationId !== 'amzn1.echo-sdk-ams.app.[unique-value-here]') {
             context.fail("Invalid Application ID");
        if (event.session.new) {
            onSessionStarted({ requestId: event.request.requestId }, event.session);
        if (event.request.type === 'LaunchRequest') {
            onLaunch(event.request,
                event.session,
                function callback(sessionAttributes, speechletResponse) {
					context.succeed(buildResponse(sessionAttributes, speechletResponse));
        } else if (event.request.type === 'IntentRequest') {
            onIntent(event.request,
                event.session,
        } else if (event.request.type === 'SessionEndedRequest') {
            onSessionEnded(event.request, event.session);
            context.succeed();
    } catch (e) {
        context.fail("Exception: " + e);
If you also need my arduino json code part: (t is the live temperature reading, while h is the live humidity reading).
            client.println("HTTP/1.1 200 OK");
            client.println("Content-Type: application/json");  // JSON response type
            client.println("Connection: close");               // close connection after response
            client.println();
            // open JSON
            client.print("{");
            // temperature
            client.print(",\"temperature\":\"");
            client.print(t);
            client.print("\"");
            // humidity
            client.print(",\"humidity\":\"");
            client.print(h);
            client.print("\"");
            // close json
            client.println("}");
My Intent Schema and Sample Utterances:
  "intents": [
      "intent": "TemperatureHumidity"
TemperatureHumidity tell me temperature and humidity
TemperatureHumidity tell me current temperature and humidity
alexa smart homethermostat
davorin avatar image
davorin answered
Alexa only allows connections to HTTPS port 443 with a valid SSL certificate...
Even for local network connections like getting a camera feed from a Raspberry Pi requires this.
MPCPRO avatar image
MPCPRO answered
So, I gotta find a way to get my arduino to post its info to another third party that has a valid SSL Certificate, which then alexa can use?
Tsuneki@Amazon avatar image Tsuneki@Amazon commented ·
Hi MPCPRO,
Please check SSL options here for details.
