vishal avatar image
vishal asked
No devices found English (India)
My skill is in language English (India) and lambda function in Ireland. When I try to discover devices with alexa, I get "No devices found". Below is the discovery output when I trigger lambda function through AWS console.
{  "event": {
    "header": {
      "namespace": "Alexa.Discovery",
      "name": "Discover.Response",
      "payloadVersion": "3",
      "messageId": "232e94f1-682e-47df-a799-35fca8473f7c"
    "payload": {
      "endpoints": [
          "endpointId": "endpoint-001",
          "manufacturerName": "Sample Manufacturer",
          "friendlyName": "Switch",
          "description": "001 Switch that can only be turned on/off",
          "displayCategories": [
            "SWITCH"
          "cookie": {
            "detail1": "For simplicity, this is the only appliance",
            "detail2": "that has some values in the additionalApplianceDetails"
          "capabilities": [
              "type": "AlexaInterface",
              "interface": "Alexa.PowerController",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "powerState"
                "proactivelyReported": true,
                "retrievable": true
              "interface": "Alexa.EndpointHealth",
              "version": "3",
              "properties": {
                "supported": [
                    "name": "connectivity"
                "retrievable": true
              "interface": "Alexa",
              "version": "3"
I don't see any logs for Lambda in cloud watch when I try to discover devices through Alexa. I do see logs for authorization during account linking.
I can also confirm that Alexa Smart Home trigger is enabled on the lambda function.
Any help in this will be highly appreciated.
alexa smart homelambdadevice discovery
2 comments
Do you have a step of serialization inside of your lambda? My skill was written in c# and I kind of had the same problem. I fixed it by returning the response as an object graph without serialization because it looks like that the engine is doing that by default. So I guess my response got twice serialized before fix and that caused my trouble.
Thanks for your reply Patrick. I am using Python so JSON serialization is not a concern. Below is my discovery v3 handler.
# v3 handlers
def handle_discovery_v3(request):
    endpoints = []
    for appliance in SAMPLE_APPLIANCES:
        endpoints.append(get_endpoint_from_v2_appliance(appliance))
    response = {
        "event": {
            "header": {
                "messageId": get_uuid()
            "payload": {
                "endpoints": endpoints
    return response
How did you debug your function? I dont see any logs or any other information to solve this.
