seonman avatar image
seonman asked
redirect_ui returns access token with # instead of ?
The redirect_ui returns access token with # instead of ?. I see somebody had the same problem before. I wonder if this issue has been figured out? What is the problem? https://harmanalexa.parseapp.com/oauthCallbackAmazon#access_token=Atza%7CIQEBLzAtAhUAjt6c-sf4tiUvLlAYO_PnMEdbX6oCFF75gx9XriTLrEV30Y5Ma63LR7RdWs-2ZYDfzAbEco8BjSeXrqUcYA2gDg7bmmO1iw0DnJ_hTyRvCfRVuynY1Eh8V_u69_icjoIHq01ihmBGEtQXHO05AwM8JXR4QoHnUZCl0Xt8JxKRy6OGfZ1plsAXEl9WGIyen3ZoNCLl_a4eEGUQukefujjR6dbEcwT2wnjqGMpd_shxl5BCZ4rZI3cQC91WlDNiF5AzyzK4ba8Z0Mn6PWn9wbO0oixbeiV5yMErb-rjsZ7MYA9hvzA3oAapD4myKPToUAnqxd3qjPOnJmyFEjfp2YARmXHwFzouk7x8BXd4H4mXQYc4yilAWF2fEpf-0oEJjNlAQWRdPFU56kxBOFo&token_type=bearer&expires_in=3600&scope=alexa%3Aall
alexa voice service
swasey@amazon avatar image
swasey@amazon answered
Can you elaborate on what you're doing to get this? It sounds like you might be attempting to do an implicit grant, is that correct? Message was edited by: swasey@amazon
