Rafael Rocha avatar image
Rafael Rocha asked
command 'ask lambda upload' results in large package
I'm using the ask cli to upload my lambda function and I noticed that the size of my function is much larger than one example I got from the blueprints. Note in the image below how smaller the blueprint function is.
I'm running the command 'ask lambda upload -f myFunction' at the root of my node project. My question is, is that normal or do I need bundle my function with something like webpack?
alexa skills kitask cli
Brian@Amazon avatar image
Brian@Amazon answered
The normal cause of a large lambda deployment package (specifically in Node.js) would be the use dependencies. This is normal, and shouldn't be cause for alarm. Are you using any imports/npm packages which would contribute to this?
2 comments
Rafael Rocha avatar image Rafael Rocha commented ·
I'm using a few npm packages and my node_modules folder is definitely the one responsible for the large package.
Is it possible to bundle the lambda in order to avoid uploading all the dependencies?
Also let's say I have a few dev dependencies (perhaps some testing framework, a test web server etc), I definitely do not want to upload those dependencies since they're used for testing purposes only. How do I deal with that scenario?
Brian@Amazon avatar image Brian@Amazon ♦ Rafael Rocha commented ·
Your best bet would be to set up a separate test environment, or make a modification/wrapper to the ask-cli such that it only zips certain subfolders.
