I would like to use ASK-CLI over proxy environment.
How should I configure?
Now AWS-CLI over proxy works with below instruction.
https://docs.aws.amazon.com/ja_jp/cli/latest/userguide/cli-http-proxy.html
But, ASK-CLI does not seem to refer the same configuration and it does not work.
ask-cli works over proxy environment except "ask lambda" command.
"ask lambda" fails as below error.
NetworkingError: connect ETIMEDOUT xx.xx.xx.xx:443
Hi there,
Thanks for posting.
My apologies for taking a while to respond. This functionality is currently not supported in the ASK-CLI. I'd suggest posting this as a feature request in our ideas space here.
Regards,
Tsuneki
Hey Tsuneki - I would like to up-vote this feature request, but I cannot, for the life of me, manage to find pre-existing requests to up-vote at that link you supplied:
https://forums.developer.amazon.com/spaces/185/index.html
If I use the search at the top, it just finds Forum posts, not feature requests I can upvote.
How can that feature request 'space' do anything useful without a workable search feature?
What am I missing???
To search feature request, you need to select "ideas" under "Of types"
1 Person is following this question.
