tifr0z avatar image
tifr0z asked
Fire OS 6: WhisperLink fails to launch services (time out error)
My app extends the com.amazon.whisperplay.fling.media.service.MediaPlayerHostService . Everything is working great with devices that use Fire OS 5, however, using the same build under the same circumstances, the service always fails to launch on Fire OS 6 device. I am enclosing the logcat capture here (2 files: one capture without any filters, another capture filtering entries relevant to the app).
servicelaunchtimeout-no-filters.txt
servicelaunchtimeout-filtered-for-app.txt
The failure manifests itself in the logs with this line (in the logs, application specific info was replaced with <app-specific-info>):
E/WhisperLink: RegistrarService - <com.company.myplayerservice> timed out trying to launch.;
Developments builds do not exhibit the behavior (the services launches as expected), I was only able to reproduce the issue with release builds.
The test device (AFTTN) has the following info under settings/device/about:
Software Version: Fire OS 6.2.1.2 (NS6212/918)
Fire TV Home Version: 6.0.1.2-006
fire tvappamazon fling
Levon@Amazon avatar image
Levon@Amazon answered
Hi tifr0z,
Thanks for letting us know. I notified the Fling team and they are preparing an update to correct this. Please keep an eye on OS updates. Thanks!
