CBert avatar image
CBert asked
Using Dynamodb with lamda nodejs with Alexa to return multiple items
I am new to all this so apologies in advance. I am trying to query a Dynamodb using nodejs and lambda so I can get Alexa to return the value. The dynamodb table is set up to look something like:
<code>date          time      filmname
2018-01-04    13:00     Titanic
2018-01-04    15:30     Titanic
2018-01-04    18:30     Paddingtion
2018-01-05    12:00     Star Wars
My table is setup with the: Primary partition key = date (String) Primary sort key = time (String)
Now what I want to do is query or get the information from dynamodb for a particular date so for 2018-01-04 3 items should return. Is this possible using nodejs within Lambda and allow alexa to read back all the items?
I have already setup the following code within my intent and this works fine:
<code>var params = {
    TableName: 'Cinema',
    Key:{ "date": "2018-01-04", "time" : "13:00"  }
docClient.get(params, (err, data) => {
    if (err) {
        this.emit(':tell', 'Test Error');
    } else {
        this.emit(':tell', 'Test Working ' + data.Item.title);
The above code returns Titanic, as expected. However, I am stuck as to how to get it to return all the items for a given date rather than just for that particular time.
I am able to run this js code standalone (i.e not in lambda) and this works fine. Although I suspect this is not the best way of doing it.
<code> var params = {
            KeyConditionExpression: "#date = :yymmdd and #time between :time1 and :time2",
            ExpressionAttributeNames:{
            "#date": "date",
        "#time": "time"
            ExpressionAttributeValues: {
            ":yymmdd":"2018-01-04",
        ":time1":'0',
        ":time2":'2'
docClient.query(params, function(err, data) {
    if (err) {
        console.error("Unable to query. Error:", JSON.stringify(err, null, 2));
    } else {
        console.log("Query succeeded.");
        data.Items.forEach(function(item) {
            console.log(" -", item.title + ": ");
Now if I run this code within Lambda (I do keep, =>, as shown in the working code) and try and test the skill I get 'The remote endpoint could not be called, or the response it returned was invalid.' Also, for some reason my cloudwatch logs are not updating for that particular lambda function so I am unable to get further information for it at this time.
Any help or guidance would be appreciated.
alexa skills kitlambdanodejsdynamodb
Tsuneki@Amazon avatar image
Tsuneki@Amazon answered
Hi there,
We really appreciate that you reach us regarding Alexa Skills Kit.
The DynamoDB Query action lets you retrieve data in a similar fashion.
You can find the detail here .
Also, I will let you know if I come up simpler solution.
