benghopy avatar image
benghopy asked
libcurl post return INVALID_REQUEST_EXCEPTION error
Hi, I just used libcurl post a request to AVS it return like: {"header":{"namespace":"System","name":"Exception","messageId":"80634b9a-f328-4029-a4ce-ce953dcf1e1a"},"payload":{"code":"INVALID_REQUEST_EXCEPTION","description":"Unexpected end-of-input: expected close marker for OBJECT (from [Source: [LineReaderInputStreamAdaptor: [pos: 0][limit: 0][]]; line: 1, column: 0])\n at [Source: [LineReaderInputStreamAdaptor: [pos: 0][limit: 0][]]; line: 1, column: 431]"}} How can I fix it ?
alexa voice service
elstryan@Amazon avatar image
elstryan@Amazon answered
Hi Benghopy, The cause of this exception is that the JSON message received by AVS from your request is not formatted correctly. Can you verify that for whichever API you are using the JSON that you are sending with your request conforms to the API documentation: https://developer.amazon.com/public/solutions/alexa/alexa-voice-service/content/avs-api-overview. Can you share an example of a body of a request that you are attempting to send?
Ara avatar image
Ara answered
Hi Benghopy, would it be possible to have a snip of your code using the libcurl. I just started to look at implementing Alexa support using libcurl and a sample code will really give me a good statrt! :)
newuser-c942babc-177c-4086-b650-eaabcea5c1fa avatar image
newuser-c942babc-177c-4086-b650-eaabcea5c1fa answered
