usernickyang avatar image
usernickyang asked ·
Questions about Managing an HTTP/2 Connection with the Alexa Voice Service
Dear Friends, I want to add avs to my android app. And after I get the login token, I find the guide says that I should use netty or jetty to managing the Http/2 connection. So is there any chances to use HttpClient or URLConnection to managing this connection or I can get some jars to use directly?
alexa voice service
swasey@amazon avatar image
swasey@amazon answered ·
You will not be able to use HttpClient (I assume you mean Apache's HttpClient) nor HttpURLConnection provided by Java. HttpClient won't have support for HTTP/2 until version 5.0, and HttpURLConnection in Java won't support HTTP/2 until Java 9. HttpURLConnection on Android is actually interesting because underneath it uses OkHttp, so technically it could receive HTTP/2 support whenever Google updates the underlying version of OkHttp to one that supports HTTP/2. However, on Android your best option is going to be to use OkHttp directly as a dependency in your application so that it supports as many versions of Android as possible. It supports HTTP/2 and is by far the best HTTP Client available for Android. You can find instructions on how to use it here: http://square.github.io/okhttp/ and it's pretty easy to add as a dependency to your Android project. Let us know if you need any further help!
usernickyang answered ·
I'll try to use OkHttp! Thank you!
Will Blaschko avatar image
Will Blaschko answered ·
I'm switching over to OkHttp as well, one thing to look out for with the switch is that the new endpoint only supports certain TLS versions, so the 4.4.2 Android device I was testing on couldn't handshake, I had to switch to a 5.* device.
Hey Will, have you seen this: https://github.com/square/okhttp/issues/1934 , and the link mentioned within: http://blog.dev-area.net/2015/08/13/android-4-1-enable-tls-1-1-and-tls-1-2/ It looks like TLS v1.2 should be enable-able since Android 4.1. However, HTTP/2 also requires ALPN (a TLS extension for protocol negotiation) which is only supported in Android 4.4+. So, you should be able to squeeze some support out of your 4.4.2 device, but that'll be the earliest version possible.
Unless I'm reading the update log for OkHttp incorrectly, it looks like they removed support for HTTP/2 for older devices (the NPN version). Looks like it's a non-starter.
