Oswald avatar image
Oswald posted
How to choose eligible ranks for your tournament
When deciding which players will recieve prizes for their accompliments in the tournament you will need to know how the eligible ranks system works. An eligible rank could be a single placement (i.e 1st, 2nd, 3rd) or a range of placements (i.e. 1st-3rd, 4th-7th, 8th-10th). It should be noted that a range of ranks can be as big or as small as you would like (i.e 1st-2nd, 3rd-1000th). Each rank, or range of ranks can be assigned different prizes, as well as multiple prizes. You can add as many single, or ranges of ranks as you would like to your tournament. One last thing to keep in mind is that you are able to edit the eligible ranks, and their prizes ONLY before the tournament is published. Once the tournament is live you will not be able to edit this section.
gameon
Oswald contributed to this article
